Auteur Sujet: "extension 4 feux pour le décodeur de signaux à 2 ou 3 feux"  (Lu 26316 fois)
trimarco232
suite à la demande de Pierrre sur https://www.locoduino.org/spip.php?article161#forum6190
   Decoder for traffic light with three or two /// or 4 leds on ARDUINO NANO
   by default the red leds are switched on
   pin 2 receives DCC interrupts
   TRAFFIC LIGHT WITH THREE leds (GREEN, RED, YELLOW)
   5 decoders of traffic lights with three leds on Arduino NANO/UNO
   the leds are controlled by pins 3 to A3 by triplet
   traffic light 1 : 3,4,5
   traffic light 2 : 6,7,8
   traffic light 3 : 9,10,11
   traffic light 4 : 12,13,A0
   traffic light 5 : A1,A2,A3
   two addresses by traffic light
   even addresses for green and red lights
   odd addresses for yellow light
   /// TRAFFIC LIGHT WITH 4 leds (green, red, yellow, carre))
   4 decoders of traffic lights with 4 leds on Arduino NANO/UNO
   the leds are controlled by pins 3 to A4 by quadruplets
   traffic light 1 : 3,4,5,6
   traffic light 2 : 7,8,9,10
   traffic light 3 : 11,12,13,A0
   traffic light 4 : A1,A2,A3,A4
   /// odd addresses for yellow and carre indications
   TRAFFIC LIGHT WITH TWO leds (GREEN, RED)
   8 decoders of traffic lights with two leds on Arduino NANO/UNO
   the leds are controlled by pins 3 to A4 by pair
   traffic light 2 : 5,6
   traffic light 3 : 7,8
   traffic light 4 : 9,10
   traffic light 5 : 11,12
   traffic light 6 : 13,A0
   traffic light 7 : A1,A2
   traffic light 8 : A3,A4
   one address by traffic light
   CONFIGURATION
   MODE : determined by the common of the led, LOW if common = HIGH, HIGH if common = LOW
   FIRST_ID_DCC : DCC address of the first traffic light
   NB_TRAFFIC_LIGHT : determined by the kind of traffic light, BICOLOR for two leds, TRICOLOR for three leds
/// modifs / ajouts pour 4 feux
//// dégobage pour modifs pour 4 feux : supprimer la ligne
              CONFIGURATION SETTING
#define CONSOLE                             // output console, comment this line after checking the soft
#define MODE   LOW                          // LOW or HIGH
#define FIRST_ID_DCC   90                   // first DCC address, DCC_CODE
#define NB_TRAFFIC_LIGHT  FOURCOLOR         //  TRICOLOR or BICOLOR /// ou FOURCOLOR
     DON'T CHANGE THE FOLLOWING
      INTERNAL PARAMETERS
//  DCC
#include "DCC_Decoder.h"                // Minabay library /// "DCC_Decoder.c" must be present too in the folder
#define kDCC_INTERRUPT    0             // pin 2 receives DCC interrupts
int previous_address = 0;               // avoids multiple DCC addresses
int previous_position = 2;              // avoids multiple DCC orders
volatile boolean update_light;          // set if an update should be processed after DCC control
// traffic light
#define BICOLOR  8                     // 8 traffic lights with two leds
#define TRICOLOR 5                     // 5 traffic lights with three leds
#define FOURCOLOR 4                    /// 4 traffic lights with 4 leds
#define FIRST_PIN         3            // pin of the first traffic light
#define GREEN             0            // address DCC/0
#define RED               1            // address DCC/1
#define YELLOW            2            // address DCC+1/0
#define CARRE             3            /// address DCC+1/1
// traffic light definition
struct light {
  int address;                    // its DCC address
  int current_position;           // green / red / yellow /// carre
  int green;                      // pin of the green led
  int red;                        // pin of the red led
  int yellow;                     // pin of the yellow led
  int carre;                      /// pin of the carre led
  boolean activation_request;     // request of activation
light traffic_light[NB_TRAFFIC_LIGHT];    // the set of traffic light
   method called if a request is made by the DCC
void activation_traffic_light() {
  for (int i = 0; i < NB_TRAFFIC_LIGHT; i++)                 // for all traffic lights
    if (traffic_light[i].activation_request == true)  // if the traffic_light is waiting for activation
      switch (traffic_light[i].current_position)           // we look the current position
        case GREEN : {                                         /// indication GREEN
            digitalWrite(traffic_light[i].green, MODE);        // switch on green
            digitalWrite(traffic_light[i].red, !MODE);         // switch off red
            if ( NB_TRAFFIC_LIGHT == TRICOLOR || NB_TRAFFIC_LIGHT == FOURCOLOR) {
              digitalWrite(traffic_light[i].yellow, !MODE);    // switch off yellow
            if ( NB_TRAFFIC_LIGHT == FOURCOLOR) {         ///
             digitalWrite(traffic_light[i].carre, !MODE);     /// switch off carre
            /**/#ifdef CONSOLE
            Serial.print("active -> signal "); Serial.print(i); Serial.println(" : green led");
            /**/#endif
        case RED : {                                         /// indication RED
            digitalWrite(traffic_light[i].green, !MODE);     // switch off green
            digitalWrite(traffic_light[i].red, MODE);        // switch on red  /// incomplet ?
            /**/#ifdef CONSOLE
            Serial.print("active -> signal "); Serial.print(i); Serial.println(" : red led");
            /**/#endif
        case YELLOW : {                                         /// indication YELLOW
            digitalWrite(traffic_light[i].yellow, MODE);        // switch on yellow
            /**/#ifdef CONSOLE
            Serial.print("active -> signal "); Serial.print(i); Serial.println(" : yellow led");
            /**/#endif
        case CARRE : {                                          /// indication CARRE
            digitalWrite(traffic_light[i].red, MODE);           /// switch on red  // incomplet ?
            digitalWrite(traffic_light[i].carre, MODE);         /// switch on carre
            /**/#ifdef CONSOLE
            Serial.print("active -> signal "); Serial.print(i); Serial.println(" : carre + red led");
            /**/#endif
    traffic_light[i].activation_request = false;            // the traffic light is updated
  update_light = false;                                        // all updates are made
    DCC method
  address -= 1; address *= 4; address += 1; address += (data & 0x06) >> 1;    // DCC address decoding
  int led = (data & 0x01) ? GREEN : RED;                                      // DCC/0 or DCC/1
  int traffic_light_index = address;                                          // index of a traffic light
  int color = led;                                                            // the color of the led
  boolean activation = false;
  if ((address != previous_address) || ((led != previous_position) && (address == previous_address))) { // if we change the address or the led
    switch (NB_TRAFFIC_LIGHT) {
      case BICOLOR : {      // if the address is in our range for traffic light with two leds
          if ((address >= FIRST_ID_DCC) && (address < FIRST_ID_DCC + NB_TRAFFIC_LIGHT)) {
            traffic_light_index = address - FIRST_ID_DCC;                                  // index of the traffic light
            activation = true;
      case TRICOLOR : {     // if the address is in our range for traffic light with three leds
          if ((address >= FIRST_ID_DCC) && (address < FIRST_ID_DCC + (2 * NB_TRAFFIC_LIGHT))) {
            if (address % 2 != 0) {
              traffic_light_index = address - 1;  // if odd address => yellow led
              color = YELLOW;
            traffic_light_index = (traffic_light_index - FIRST_ID_DCC) / 2;                  // index of the traffic light
            activation = true;
      case FOURCOLOR : {     /// if the address is in our range for traffic light with 4 leds
              if (data & 0x01) color = CARRE; else color = YELLOW; /// en fonction du poids faible
            activation = true;
            /**/#ifdef CONSOLE
            Serial.print("s"); Serial.print(traffic_light_index); Serial.print(" a"); Serial.print(address); Serial.print("/"); Serial.print(data & 0x01); Serial.print(" ");
            /**/#endif
    traffic_light[traffic_light_index].activation_request =  activation;    // activation is requested
    traffic_light[traffic_light_index].current_position = color;            // state is requested (color of the led)
    update_light = activation;                                              // traffic light update is requested
  previous_address = address; previous_position = led;                     // the current activation is saved
    setup
#ifdef CONSOLE
  delay(1500); /// compatible debogage promicro
  int pin_jump = 0;                                                    // a jump for traffic light pins
  int traffic_light_jump = 0;                                          // a jump for traffic light number
  for (int i = 0; i < NB_TRAFFIC_LIGHT; i++) {                         // for all the traffic lights
    traffic_light[i].activation_request = false;                       // no activation request
    traffic_light[i].green = pin_jump + FIRST_PIN;                     // pin number of the green led
    pinMode(traffic_light[i].green, OUTPUT);                           // green led in output(ID DCC/0)
    digitalWrite(traffic_light[i].green, !MODE);                       // green led switch off
    traffic_light[i].red = 1 + pin_jump + FIRST_PIN;                   // pin number of the red led
    pinMode(traffic_light[i].red, OUTPUT);                             // red led in output  (ID DCC/1)
    digitalWrite(traffic_light[i].red, MODE);                          // red led switch on
    if (NB_TRAFFIC_LIGHT == TRICOLOR || NB_TRAFFIC_LIGHT == FOURCOLOR ) {   // if 3 leds /// or 4 leds
      traffic_light[i].address = traffic_light_jump + FIRST_ID_DCC + i;   // its DCC ID
      traffic_light[i].yellow = 2 + pin_jump + FIRST_PIN;              // pin number of the yellow led
      pinMode(traffic_light[i].yellow, OUTPUT);                        // yellow led in output  (ID DCC+1/0)
      digitalWrite(traffic_light[i].yellow, !MODE);                    // yellow led switch off
      traffic_light_jump++;                                            // the following traffic light
      pin_jump += 3;                                                   // the following pin for three leds
      if (NB_TRAFFIC_LIGHT == FOURCOLOR) {                             /// if 4 leds
        traffic_light[i].carre = pin_jump + FIRST_PIN;
        pinMode(traffic_light[i].carre, OUTPUT);                       // carre led in output  (ID DCC+1/1)
        digitalWrite(traffic_light[i].carre, MODE);                    // carre led switch on
        pin_jump += 1;                                                 /// the following pin for 4 leds
    else {                                                             // if two leds
      traffic_light[i].address = FIRST_ID_DCC + i;                     // its DCC ID
      pin_jump += 2;                                                   // the following pin for two leds
  DCC.SetBasicAccessoryDecoderPacketHandler(BasicAccDecoderPacket_Handler, true);   // instanciate the DCC
  DCC.SetupDecoder( 0x00, 0x00, kDCC_INTERRUPT );                                   // its IT
  update_light = false;                                                             // no update
#ifdef CONSOLE
  //// Serial.begin(115200);
  Serial.println(""); Serial.println(""); Serial.println(""); ///
    Serial.print("traffic light "); Serial.println(i);
    Serial.print("\t green led on pin : "); Serial.print(traffic_light[i].green); Serial.print(" , DCC address : "); Serial.print(traffic_light[i].address); Serial.println("/0");
    Serial.print("\t red led on pin : "); Serial.print(traffic_light[i].red); Serial.print(" , DCC address : "); Serial.print(traffic_light[i].address); Serial.println("/1");
    if (NB_TRAFFIC_LIGHT == TRICOLOR) {
      Serial.print("\t yellow led on pin : "); Serial.print(traffic_light[i].yellow); Serial.print(" , DCC address : "); Serial.print(traffic_light[i].address + 1); Serial.println("/0");
    else   if (NB_TRAFFIC_LIGHT == FOURCOLOR) { ///
      Serial.print("\t carre led on pin : "); Serial.print(traffic_light[i].carre); Serial.print(" , DCC address : "); Serial.print(traffic_light[i].address + 1); Serial.println("/1");
   loop
  DCC.loop();                   // Is there a DCC command ?
   delay(2000) ; ////
   BasicAccDecoderPacket_Handler(24, 1, 2); ////
  if (update_light) {
    activation_traffic_light(); // if yes, activation of traffic lights
   delay(2000) ; ////
   BasicAccDecoderPacket_Handler(24, 1, 5); ////
   if (update_light) { ////
    activation_traffic_light(); // if yes, activation of traffic lights ////
édits : regarder svp. la date du dernier Modifié pour s'assurer d'avoir la dernière version
« Modifié: juin 24, 2022, 03:25:47 pm par trimarco232 »
Re : "extension 4 feux pour le décodeur de signaux à 2 ou 3 feux"
« Réponse #1 le: juin 24, 2022, 11:01:19 am »
parfait, testé sur les premières adresses sans problème.
trimarco232
« Réponse #2 le: juin 24, 2022, 11:36:48 am »
Bonjour msport,
merci pour le test, car j'ai dû me contenter de faire des simulations
PETER41
« Réponse #3 le: juin 24, 2022, 05:11:46 pm »
Un très grand merci pour ce travail.
Pour ma part j'ai dessiné la carte imprimé et j'espère la câbler d'ici mercredi prochain pour faire l'essai au club.
Je vous tiendrais informé dès que j'aurais fait ces essais (centrale digikeys et logiciel Trancontroller Gold).
Arduinotement vôtre.
PETER41
« Réponse #4 le: juillet 05, 2022, 06:39:25 pm »
La carte est câblée. Mise sous tension :
Toutes les leds red sont allumées, les leds "carré" sont allumées mais la sortie A0 "clignote".
En mettant la console il y a en effet une commande alternée red puis carre + red. Donc cela produit le clignotement de la led carre.
J'avais fait un essai la semaine dernière et cela faisait cela au club même quand le DCC était alimenté et avec la manette ROCO impossible de commander les feux. Mais je n'avais pas l'ordinateur portable et je ne pouvais pas voir ce qui se passait.
Je ferais un nouvel essai demain AM.
Je ne comprends donc pas ce qui se passe. Je n'ai pas mis de condensateur sur les entrées de l'optocoupleur. Sur la version 3 leds non plus et cela fonctionne donc ?
Je me suis dit que mon circuit avait un PB. J'ai donc fait un câblage sur bredboard et cela produit le même effet (sans signal DCC). Pourtant en regardant les photos de MSPORT cela fonctionne !
Je vous donne des nouvelles jeudi après essai au club demain AM.
Arduinotement vôtre
PETER41
« Réponse #5 le: juillet 07, 2022, 04:55:17 pm »
Voici les nouvelles :
Il semblerait que les commandes DCC ne sont pas effectives :
1- Supposition 1 : L'optocoupleur a un PB. J'ai donc pris l'optocoupleur de la carte 3 leds et je l'ai mis sur la carte 4 leds. Même effet.
J'ai même mis l'optocoupleur de la carte 4 leds sur la carte 3 leds et la carte 3 leds fonctionne.
Donc optocoupleur OK
2- Pb de la carte CI que j'ai fait : J'ai donc mis l'Arduino avec le PRG 3 leds et la carte fonctionne parfaitement. Donc le CI est OK.
J'ai mis l'Arduino avec le prg 4 leds sur la carte 3 leds et le fonctionnement n'est pas bon : les cdes DCC ne produisent rien.
L'allumage des leds est celui décrit précédemment.
Pour mettre le programme dans l'Arduino j'ai fait un copier du PRG en faisant sélectionner puis copier et mis ensuite dans l'éditeur de programmation Arduino. Est-ce cela qui pose un PB. Est-il possible d'avoir le fichier .ino et téléchargement ?
Merci pour votre aide car là je bloque complètement.
Dans l'attente de votre réponse.
« Réponse #6 le: juillet 07, 2022, 10:10:50 pm »
vous pouvez essayer cette version qui ne doit pas être très différente de celle de trimarco232
https://forum.locoduino.org/index.php?topic=1429.msg15510#msg15510
je pense avoir corrigé le bug.
PETER41
« Réponse #7 le: juillet 08, 2022, 06:46:30 pm »
Cher MSPORT,
Je viens de télécharger ton PRG. Mais comme je n'ai pas fait TRES attention au premier essai PAF le chien.
Ensuite j'ai regardé ton PRG et j'ai vu que l'adresse de début était 10 ... Petit piège car j'ai fait mon premier test à partir de l'adresse 90 ! C'est ce qui était pour le 3 leds et que TRIMARCO232 avait pris aussi.
Et là essai à partir de l'adresse 10 tout fonctionne : BRAVO et surtout UN GRAND MERCI pour ton aide.
Dois-je déduire que le PRG de TRIMARCO que j'ai fait en copier coller pose un PB par cette méthode de copier coller (et non pas du PRG lui-même).
Encore tous mes remerciements à vous deux. Cela me (nous) montre que la communauté ARDUINO est TOP.
Je ferais des photos des cartes et je les mettrais sur le forum.
ARDUINOTEMENT VOTRE
« Réponse #8 le: juillet 08, 2022, 08:00:29 pm »
Très heureux que ça marche.
C'est probablement dans le transport que quelques octets se sont perdus puisque c'est également avec un copié collé que j'ai récupéré le programme de trimarco232 et qu'il a fonctionné sans problème (avec une adresse de départ modifiée)
trimarco232
« Réponse #9 le: juillet 12, 2022, 12:38:10 pm »
félicitations à Pierre, l'audace (car il en faut à ce stade) a payé  8)
j'avais édité mon pgm, principalement pour clarifier les commentaires, mais peut-être un loup s'y est glissé
quoiqu'il en soit, adopter le pgm de msport me semble la bonne option, car msport a déjà (si j'ai bien suivi) fait quelque chose pour adapter ça aux logiciels qui décalent les adresses : on aura bien un jour une demande en ce sens, msport sera prêt  ;)
je laisse mon pgm pour mémoire, ça sera peut-être utile quand on envisagera les allumages et extinctions progressifs
